It is currently Sun Feb 18, 2018 4:30 pm
 Post subject: WANTED meter shunt
PostPosted: Mon Feb 12, 2018 2:38 am
I am looking for a meter shunt to go with a EMD ammeter (EMD part #8402426).
This is going to go into a locomotive that doesn't have a ammeter for the traction motors, its basically an SW1.
 Post subject: Re: WANTED meter shunt
PostPosted: Mon Feb 12, 2018 12:08 pm
Try eBay. I have seen many shunts listed. First find out the rating of your meter, typically 50 millivolts, and then find a 50 mv shunt that will work with your meter.
PostPosted: Thu Feb 15, 2018 11:20 pm
is this a locomotive that never, ever had an ammeter? If so, you'll need to cut into the traction
motor circuit someplace to install the meter shunt. Pick a meter with a full-scale reading that
makes sense for the HP rating of your locomotive. Pick a shunt with a corresponding FS reading
(e.g. 2000A) and, as the other poster says, usually a 50mV full-scale drop (match it to the
amp meter, the mV F.S. should be written in fine print near the bottom of the scale)
Users browsing this forum: No registered users and 5 guests
