It is currently Sat Feb 29, 2020 6:50 am
 Post subject: For Sale: EMD Parts
PostPosted: Sun Feb 09, 2020 7:03 pm
For Sale:
72 New National Carbon, EMD #40047198 carbon brushes for D87 traction motors; $720.00
1 Reconditioned EMD Style Mercor Corp. voltage regulator with reference port; $500.00
1 Used "RTO" EMD Style Mercor Corp. voltage regulator with reference port, removed from a recently scrapped EMD SD24 locomotive: $300.00
2 Used "RTO" EMD small water pumps removed from a scrapped 12V567B engine: $300. each
2 Used EMD small water pumps removed from a scrapped 12V567B engine.These pumps have small cracks in the back of them from freeze damage. I see nothing wrong with the impeller, shaft or gear. These are being sold for parts. $150.00 each
2 RTO EMD oil pumps removed from an EMD 12V567B engine, $500. each
24 used EMD valve bridges from 12V567B engine: $35.00 each
2 Used EMD air-cooled 6 cylinder air compressor heads, being sold as cores. One low pressure and one high pressure, $300. for both heads.
6 Cylinder EMD air compressor gaskets;$200. for all 11 gaskets
6 #8068830
5 #8068810
14 EMD #8272599 Electro-Magnetic Power Contactors; $250. each
Discount if you buy all 14.
EMD Electro-Magnetic Reverser and Braking Switches; $250. each
4 #8251143
2 #8251526
3 #8249332
2 with number tag missing.
EMD Motor Field Shunt Resisters, all from an SD24: $100. each
1 #8263271
1 #8363271
1 #843071
1 #843081
1 #843112
1 #843115
2 EMD #8411512 Transition Relay, "BTR" and "FTR" $250. each
These also have Wabco #433875 VE-9T Neutral D.C. Relay on them.
These are also from an EMD SD24
EMD dual sealed beam headlight assembly, from SD24 $75.00 each
EMD carbody door latches $10.00 each
All parts are priced less shipping.
James Kopkey
jkironhorse251@aol.com
Users browsing this forum: No registered users and 5 guests
