It is currently Fri Jun 05, 2020 8:43 am
 Post subject: wtb: Caboose sliding windows
PostPosted: Sun Apr 12, 2020 11:12 pm
I need a pair of sliding cupola windows for my wide vision cab. They measure 20x28. I've been in contact with what became of JT Nelson and haven't heard back. Does anyone out there in rypn land happen to have a pair near the Ohio Valley?
Joe
googanelli@aol.com
 Post subject: Re: wtb: Caboose sliding windows
PostPosted: Thu Apr 16, 2020 10:13 pm
I'm pretty sure some later built cabooses actually used EMD loco side windows. EMD used those same windows from GP-7's till they went to the wide cab locomotives.
PostPosted: Fri Apr 17, 2020 8:59 am
I'm probably going to have to try that route first. I spoke with what became of JTNelson and they have suggested the same. I could try to get my windows replaced with lexan or similar. I am waiting for a call back from my local MP&E inspector about the windows right now. I see a part of 49CFR223.3 that looks like it allows for me to replace them with non type 1 or 2 glass if used in preservation. If that ends up being the case, I'll do it.
Thanks for the suggestion.
Joe
PostPosted: Fri Apr 17, 2020 3:06 pm
As long as your caboose isn’t in revenue service on a general system railroad, you are exempt from Part 223 glazing requirements.
Orrville Railroad Heritage Society
Car Knocker, Gandy Dancer & Hog Jockey
https://orrvillerailroad.com
PostPosted: Fri Apr 24, 2020 10:00 pm
I got that word back from my local MP&E inspector. I will just end up replacing the glazing inside with lexan.
Thanks for the info and help!
Joe
PostPosted: Sat Apr 25, 2020 7:28 am
You might consider acrylic instead of polycarbonate (Lexan). Acrylic is more UV stable and in my opinion, a little easier to work with. True, it is less impact resistant, but still better than glass. Acrylic is usually less expensive, too.
PostPosted: Fri May 08, 2020 10:14 am
Joe,
I need to replace the glazing in all of mine too.
Are yours like this?
I am thinking of using laminated glass like a windshield if I can get the frames apart.
Bill
PostPosted: Sun May 10, 2020 9:02 am
My windows are that style. Your's look narrower. Mine were 28x22. Locomotive windows are 18 3/4 x28. You may be able to get away with just putting in loco windows.
I ended up going with 1/2 lexan. I was able to source both window replacements for $170.
Joe
PostPosted: Thu May 14, 2020 9:39 pm
I used the laminated glass for just a little less. Nice to have clear windows in the bay. As long as nobody shoots at it we should be fine... Now for the rounded ones.
Users browsing this forum: No registered users and 5 guests
