It is currently Mon Jul 13, 2020 1:11 am
 Post subject: For Sale: Track Maintenance Equipment.
PostPosted: Mon Jun 22, 2020 9:38 am
For Sale:
Fairmont Scarifier believed to be a Model W-87 equipped with a Detroit diesel engine.
It is also equipped with a cable system to pull railroad ties into the hole it makes.
Mark II Electromatic tamper with a Detroit diesel engine.
At one time, this tamper had an light aligning system.
It has only been used for spot tamping by it's current owner.
The Scarifier and Tamper have been stored inside for a number of years and have not been run for some time. Both will need batteries. They both worked when last used.
Also have a small portable spiker, do not know who made it. It is air operated and does both spikes on one rail, then you have to turn it around to do the other rail.
To run the spiker is an Ingersoll Rand 4 cylinder air compressor with a 4 cylinder Continental gasoline engine. This is a skid mounted compressor to sit in the back of a truck or on a small flat cart.
1980 Chevy C30 stepside pickup with hy-rail gear. It has a 292 inline 6 cylinder gasoline engine. The pickup is ex-Conrail and the body is a little rough, but run well.
All equipment has been stored inside.
We would like to make a package deal on this equipment at $8,000 but we will separate it.
Contact James Kopkey at jkironhorse251@aol.com
Users browsing this forum: No registered users and 13 guests
