It is currently Sat Nov 28, 2020 3:38 pm
 Post subject: For Sale EMD Parts
PostPosted: Sat Aug 15, 2020 12:30 pm
Parts for sale from a parted out/scrapped EMD SD24;
Recently Rebuilt Lube Oil Cooler, "RTO" $1,750.00
{This will fit most late model EMD locomotives, GP30, Gp35, GP38, etc.}
Mercor Model VR400 Voltage Regulator $300.00
Edison Reverse Current Rectifier Model 200 $175.00
2 48 inch cooling fans $250.00 each
Relays for 48 inch cooling fans;
#8247364 Relay "AC1" $200.00
#8332661 Relay "AC2" $200.00
#8399037 Relay "AC2" $200.00
1 #8467161 Voltage Regulator for Dynamic Brake $300.00
3 #8251532 Relay, Dynamic Brake, Transition $125.00 each
1 #8254149 Relay, Field Shunt, Forestalling $125.00
2 #8347433 Relay, $175.00 each
1 #8158951 Rectifier, $50.00
14 #8272599 Electro Magnetic Contactors $125.00 each
11 Electro Magnetic Reverser & Braking Switches; $125.00 each
4 #8251143
2 #8251586
3 #8249332
2 missing tags
1 Sequence Test Panel $75.00
1 #8172591 Relay, Wheel Slip $150.00
6 EMD Traction Motor Field Shunt Resisters; $100.00 each
#8263271
#836327
#843071
#843081
#843112
#843115
EMD Door Latches $10.00 each
8 Old Style EMD Screw Type Slack Adjusters $1,000. for lot.
{ These all turn easily by hand. Would work on "F" units.}
All prices are less shipping.
Contact through this ad or jkironhorse251@aol.com
James Kopkey 317-877-1312
Items are located in Kokomo, Indiana.
Users browsing this forum: Kelly Anderson and 6 guests
