It is currently Wed Nov 04, 2026 6:01 am
 Post subject: C&O Steamer to move
PostPosted: Tue Mar 25, 2003 6:00 pm
http://www.trainorders.com/discussion/r ... 3&t=122153
Trainorders Thread
trains@robertjohndavis.com
 Post subject: Re: C&O Steamer to move
PostPosted: Tue Mar 25, 2003 7:08 pm
I do hope that someone will get pictures and post ,,thank you PAT
cprh1b@attbi.com
PostPosted: Wed Mar 26, 2003 9:32 am
> It will be interesting to see how they uncouple the engine from the tender given that the drawbar pins haven't been out since the 1950s'and are held in tension by the springs in the buffer. When we moved Milwaukee Road No. 265 out of a park it took us days to get a draw bar pin out. Knowing riggers they'll probably end up torching the drawbars. J.David
jdconrad@snet.net
PostPosted: Wed Mar 26, 2003 10:34 am
When we finally separated the tender from the locomotive on OUR K-4 (C&O #2789) a few year ago, it was a chore. But it can be done! Hope that the movers don't just torch the drawbars. Time will tell I guess.
midlandblb@cs.com
PostPosted: Wed Mar 26, 2003 1:21 pm
J.David,
Can you post pictures of the locomotive that you have been working on down in Texas?
Any comments about the job?
i gather that she will now be displayed inside?
ted_miles@nps.gov
 Post subject: 2-8-4 drawbar pins
PostPosted: Wed Mar 26, 2003 4:19 pm
Neither heat, nor jacking against the weight of the locomotive, nor freezing the pin with liquid nitrogen worked on PM 1225. This was due to rainwater flowing out of the coal in the stoker tube and onto the pin. The pin on the engine had to be drilled out with a magnetic drill press (it's about 14 inches long) and the remainder burned out with an air arc.
I think the Kanawhas have roller bearings, so the fellows in Richmond will be saved the joy of polishing all those journals. This makes me recall the story of one former Kanawha owner who found out how easily these things roll downhill if you don't air up the brakes or properly attach a really big bulldozer for an anchor.
Aarne Frobom
P. O. Box 665
Owosso, MI 48867-0665
