It is currently Mon Oct 05, 2026 4:58 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: C&O 4-4-0 in Church Hill Tunnel Richmond, VA
PostPosted: Tue Feb 26, 2008 7:57 pm
About two years ago someone was attempting to salvage the C&O 4-4-0 that was buried in the Church Hill Tunnel in Richmond, VA. Did anything ever come of that?
Kevin Kohls
 Post subject: Re: C&O 4-4-0 in Church Hill Tunnel Richmond, VA
PostPosted: Tue Feb 26, 2008 9:18 pm
Kevin Kohls
Kevin -
Glad you asked the question. I have been wondering myself. This seemed to be a legitimate attempt to recover the C&O 4-4-0, and possibly any other equipment, and also to see if the remains of the two missing workers could be found. I seem to recall that there was a problem with water in the tunnel, but that seems to be where it was left.
Update anyone?
PostPosted: Tue Feb 26, 2008 9:50 pm
I got 4 pages of stuff on a Google search. Couple of websites with information but all outdated. One site had a research pdf dated 2006 and another had an entry dated 2007. Basically nada.
Robin
PostPosted: Tue Feb 26, 2008 10:27 pm
Here's the last thread:
http://rypn.sunserver.com/forum/viewtopic.php?t=20984&highlight=richmond
"As veteran B&LE engineer 'Tex' McCann observed, if Pennsylvania had a drawbar on it, a Bessemer 400 (DRS6-6-1500) would surely try to 'shake and wiggle' it."
PostPosted: Tue Feb 26, 2008 10:33 pm
That string was about the 4 loco's in scrap yard.
Robin
PostPosted: Tue Feb 26, 2008 10:34 pm
I just noticed & corrected it. Sorry!
PostPosted: Wed Feb 27, 2008 12:32 pm
trainspot wrote:
So, its been over a year and a half ago that "the hydrologist and the city engineering department are going to study this....." It would seem that perhaps the study should have been done by now. Perhaps if Pete Claussen is still on RyPN, he might give us an update of what has, or has not, been going on.
PostPosted: Wed Feb 27, 2008 2:59 pm
The locomotive is about a block from the West end of a tunnel that is about 1100 feet long, as I recall, that slopes upward to the East and is full of water and muck. In the past some buildings on up the hill have collapsed on account of changes in the water pressure that were attributed to the tunnel. If the water is drained from the tunnel as part of a recovery effort, there appears to be a substantial posibility that additional buildings could collapse or be damaged. The alternative would be to somehow seal off the tunnel to the East of the locomotive and then dig it up. Estimates of the total cost of doing this were in the $5 million range so the project was abandoned.
The locomotive definately is still in the tunnel.
Pete Claussen
PostPosted: Wed Feb 27, 2008 3:18 pm
If you can run a robotic camera on the surface of Mars then why not under the streets of Richmond?
Robin
PostPosted: Wed Feb 27, 2008 4:45 pm
Pete Claussen
Pete -
This is probably a stupid question, but as the water is slowly drained from the tunnel, couldn't air be pumped in to keep the pressure constant? At a lot less than $5 million? This still seems like a do-able reclaimation project.
PostPosted: Wed Feb 27, 2008 4:51 pm
Furthermore, hydrostatic pressure is only as good as the weight of the water continues to support the sides of the tunnel. If buildings have previously collapsed, I would suggest those dependent on the water in the tunnel are "built on shifting sands", so to speak. I would suggest the best alternative is to evacuate the buildings, remove the water, remove the locomotive, backfill the tunnel or secure the walls with something other than water. Of course, they never asked me.
PostPosted: Wed Feb 27, 2008 9:54 pm
On the plus side, it would seem easy to model this.
Where does the actual problem come in - is it from a release of
pressure when opening a sealed tunnel... as someone had mentioned, why can't "something" be pumped in to replace the water that is pumped out? Well, all at a cost, I suppose.
PostPosted: Thu Feb 28, 2008 8:07 am
Find myself agreeing with Richard (again). The support of a stable water table is one thing, we have seen some relatively new homes on slabs shift during our recent drought in the Southeast. Holding up a mountain with a tunnel full of water well above the water table is another. There will be a blowout and the water will disappear some day. This is kind of like those towns built on burning coal mines, eventually sinkholes happen and buildings disappear. Why not either remove the structures and deal with it, or make a plan to drain and reinforce the tunnel - in sections of necessary - if preserving the structures is required?
PostPosted: Thu Feb 28, 2008 8:54 am
$5 million is a lot of money to save one engine that no one has seen in decades. I think you guys could spend a quarter of that on the engines sitting in the scrap yard. At least you know what you are getting!
PostPosted: Thu Feb 28, 2008 9:21 am
Yeah, for one choo-choo that has been crushed by a cave-in and spent many decades underwater like the TITANIC, $5 million is definitely a lot of money. I can think of a lot of things that need that money more urgently.
MX
"We Repair No Locomotive Before Its Time"
