It is currently Wed May 14, 2025 6:49 am
 Post subject: Another New Locomotive
PostPosted: Sat Dec 06, 2008 11:37 am
Hello,
Another new steam locomotive has been built from the rails up. This fine piece of work has come from the Meiningen Locomotive Shop in Germany. Yes, it's a German design, but steam is steam and this is a nice example. Apparently, the railway needs more motive power-----how great is that?
Meiningen is one of the last complete steam builders and as can be seen on their site, it appears to be a quality shop.
http://www.molli-bahn.de/Dampflokomotiv ... 295.0.html
Respectfully,
Dave Griner
arizonamechanicalengineering.com
Dave Griner
 Post subject: Re: Another New Locomotive
PostPosted: Sat Dec 06, 2008 2:08 pm
That sure is interesting work seeing all those parts being made and coming together. It is somewhat surprising to see a drafting board and track drafting machine in the photos.
PostPosted: Sat Dec 06, 2008 10:18 pm
Very good news. Newly produced steam will help keep steam going for generations.
Tom Gears
Wilmington, DE
PostPosted: Sun Dec 07, 2008 5:31 pm
Interesting to see that the cylinders are fabricated! Cheaper than making the patterns for casting, and presumably substantially lighter too.
PostPosted: Tue Dec 09, 2008 4:07 am
This is the same shop that built the LNER Peppercorn Class A1 boiler a few years ago. I wonder if they could build a boiler for the PRR 1361?
PostPosted: Tue Dec 09, 2008 7:25 am
I'm sure they could if someone could afford to pay for it.
PostPosted: Tue Dec 09, 2008 9:10 am
In England they have worked out a way that supporters pledge a monthly payment to support ongoing projects. Here in the states we ask for donations and have levels of support; $100 - trainman, $200 brakeman, $300 engineer, $500 trainmaster.
I wonder how it would work if organizations here tried to get a larger number of people to pledge $20 per month instead of going for the big once a year donation. This would provide a steady source of funding and in theory if you were able to keep adding folks as you go along it would grow at a steady rate.
This might be the way to take on a K-4 project... or maybe a B&O pacific instead. :-)
Tom Gears
Wilmington, DE
PostPosted: Tue Dec 09, 2008 11:29 am
I would note that the German locomotive was purchased by an operating railroad as an asset to be used to generate revenues, not a non-profit, publicly funded "Let's replicate a lost class" project. Very different circumstances.
Also, adaptation of modern production techniques in replicating an old design is a wonderful demonstration of how it has never been easier or better technologically do build a new steam locomotive than it is today - economically, maybe not so much......unless one is in the happy circumstances of the Mecklenburg narrow gage.
FW&W could benefit from their fabricated cylinder / saddle production techniques for their one-off repair job, relative to creating patterns for just one use. Perhaps if they sent the busted casting to Meiningen a new replacement fabrication could be returned to be bolted on?
PostPosted: Tue Dec 09, 2008 12:10 pm
The use of modern fabrication techniques in steam locomotive production have interested me. I know the PRR used fabricated cylinders and cylinder saddles, but did any other U.S. railroad or builder use the technique? I remember reading that the Pennsy used a large oven to heat the completed cylinders and saddle to relieve stress. Do you have to still do this today?
I always theorizied that if steam locomotive production continued in the U.S., that the then high-tech casting technology would have given way to welding and fabrication of the "large bits" of a locomotive, including frames and cylinders.
PostPosted: Tue Dec 09, 2008 12:43 pm
Yes Dave! A weldment cylinder would be the way to go, recommend they contact Wasatch Railroad Contractors. Dave Griner has already designed a weldment cylinder for a much larger locomotive though it was never built.
In regards to other locomotives having weldment cylinders, if my rememberer is working...the santa fe applied a weldment cylinder with ?poppet? valve gear (experimenting with modern valve gear design)to one of their 4-8-4s.
PostPosted: Tue Dec 09, 2008 1:17 pm
Meiningen has already replaced the old cast cylinders on the rest of this class with fabricated assemblies. The Australian version of N&W 611, the 3800 class, were built with fabricated cylinder saddles. Nothing truly new about it - just postdated our steam era.
Based on what I have heard about fabricated complex assemblies, I do believe stress relieving through controlled heat cycling is a very good idea. It is being done in even simple weldments, like replacing a chunk of boiler shell now. It has also been done with castings - the only warm place at Glover's in January was next to the annealing oven when we were baking out a new truckload of unfinished castings from the Cordele foundry.
I'd wager there are several vendors that could provide it - but I don't know who in this country has had the specific experience found at Meiningen. I have a few ideas who not to call........
Users browsing this forum: No registered users and 95 guests
