It is currently Wed Oct 28, 2026 4:02 am
 Post subject: part 230 question
PostPosted: Wed Jun 19, 2002 1:11 pm
230.62 requires the drypipe to be inspected for thickness at each annual inspection.
If the boiler in question is small, it'd be virtually impossible to get a person in there with a meter and a grinder. Any suggestions?
Thanks
Rudd
rudd@cogdellmendrala.com
 Post subject: Re: part 230 question
PostPosted: Wed Jun 19, 2002 1:25 pm
Dear Rudd:
The method of determining the thickness is
not specified, you need not use an ultra-sonic tester for this task. Why not use calipers?
J.David
jdconrad@snet.net
PostPosted: Wed Jun 19, 2002 4:25 pm
The drypipe can be removed if necessary. Very small boilermakers can be hired. If the steam pipes and T are removed from the smokebox, tests may be peformed as readily from the inside of the pipe as from the outside.
Dave
irondave@bellsouth.net
PostPosted: Wed Jun 19, 2002 6:53 pm
Well Rudd;
You can find a real skinny boilermaker, or you can remove the drypipe, or you can remove the steam lines and T and UT from the inside of the pipe.
Dave
