It is currently Mon Nov 16, 2026 9:08 am
 Post subject: Sprung Points
PostPosted: Tue Apr 12, 2011 12:28 pm
Would some knowledgeable person please explain what "Sprung points" are? I have searched the "net" and can't seem to find an explanation.
Thanks
Robert
FVHRS
 Post subject: Re: Sprung Points
PostPosted: Tue Apr 12, 2011 12:32 pm
Try "spring switch" instead:
http://modeltrains.about.com/od/smodelr ... Switch.htm
"Sprung points" is/would be British rail jargon, as "points" are what we Yanks call "switches." On model railroads, the term "turnout" is used to distinguish from electrical switches.
PostPosted: Tue Apr 12, 2011 12:57 pm
In Harry Bedwell's "Eddy Sand" stories in "Railroad" magazine, "sprung points" were the result of trailing through switch points that were set to the other route. A 2008 example happened just North of Chatsworth, Calif.
PostPosted: Wed Apr 13, 2011 10:49 am
I would concur with Mr. Boylan. "Sprung points" in our context refer to the condition of a switch that is neither a spring switch nor a semi-automatic switch that has experienced a trailing movement in one direction while set for the other ("run through"). A switch that has experienced this usually has its hardware bent to the extent that it will not close in one position or the other. The remedy is to take it out of service and/or spike it in its "normal" position until the smith has rehabbed it.
PostPosted: Wed Apr 13, 2011 12:10 pm
Rather than "sprung", I'd call it damaged. Or "twanged". Why mince words?
PostPosted: Wed Apr 13, 2011 1:27 pm
Beats me ... that's what the old heads called it.
PostPosted: Wed Apr 13, 2011 4:51 pm
I usually heard the occurrence referred to as "run-through". I would add that there is a way to set up a switch that it can be easily fixed - that is by using breakaway lugs in the mechanism that let go, instead of bending the throw rods or other parts. They aren't used because crews can get access to them and fix the switches themselves so their "oopses" can be covered up, and they could avoid disciplinary action for the run-through. I would suggest that any tourist railroad or museum operation that has not heard of them should look into using them on their track, since they wouldn't be so hung up on "firing" volunteer crews for their mistakes, and would save a lot of time and money on track repairs and maintenance.
PostPosted: Wed Apr 13, 2011 5:20 pm
Make every turnout that gets regularly "run through" (thats the term that I heard used on the AT&SF) a spring or "S" switch/turnout, that solves the problem.
PostPosted: Wed Apr 13, 2011 7:31 pm
Best solution to damaged switches due to being run through is to force the guilty parties to do the repairs themselves. They'll be much more careful next time... no more "sprung" switches.
But spring switches can be awfully convenient on sidings which are consistently used for meets and running around trains for the return trip.
Steve Hunter
PostPosted: Thu Apr 14, 2011 11:09 am
sbhunterca wrote:
But spring switches can be awfully convenient on sidings which are consistently used for meets and running around trains for the return trip. Steve Hunter
That is very true for mainline operations. Most run-throughs happen in yards or industrial sidings. When I was in Germany a couple of years ago, I noticed that most of the mainline platform station switches (outside of endpoints like Wernigerode and the mountaintop at Brocken) on the Harz Mountain Railroad appeared to be spring switches. Makes for a much quicker operation.
PostPosted: Thu Apr 14, 2011 12:47 pm
Am I correct in remembering that spring switches are used at the Strasburg Rail Road, which at times in the summer has almost streetcar-like frequency?
PostPosted: Thu Apr 14, 2011 2:06 pm
Our mainline switches at National Capital Trolley Museum are spring switches, including one street switch.
Wesley
PostPosted: Thu Apr 14, 2011 4:36 pm
Sandy, yes.
PostPosted: Thu Apr 14, 2011 4:39 pm
PaulWWoodring wrote:
... Most run-throughs happen in yards or industrial sidings ...
Paul, that's correct.
PostPosted: Thu Apr 14, 2011 5:07 pm
And they come in threes, like most bad things that happen on the railroad. Or, 2 other bad things happen about the same time. Waiting for that last of them to happen is real frustrating.
