It is currently Tue Nov 03, 2026 12:29 am
 Post subject: Wheel Stops
PostPosted: Wed Aug 31, 2011 11:27 am
Can anyone recommend a wheel stop to be used to prevent cars and locomotives from travelling further down the track once parked- one which is easy to remove and replace, perhaps lighter of weight than another, for tracks sizes 60 pounds to 90 pounds?
Also - does anyone have wheel stops they would care to sell? We need about seven. Cheap is always good for Museums.
Jim Lundquist, Pacific Southwest Railway Museum
 Post subject: Re: Wheel Stops
PostPosted: Wed Aug 31, 2011 12:43 pm
The fine folks at McMaster Carr sell these wheelstops.
check out the link below...
http://www.mcmaster.com/#railroad-wheel-chocks/=duz3uk
PostPosted: Wed Aug 31, 2011 12:55 pm
Thanks. I saw those. A bit expensive. I'm thinking that someone has a pile of these in the "back 40" and would like to sell them cheap.
"I intend to live forever.... so far, so good."
PostPosted: Wed Aug 31, 2011 1:39 pm
You make it sound like you want something temporary, and movable. You might want to look at wheel chocks (dedicated ones, not pieces of crushed pallet) or rail skates. The rail skates have the advantage that they can't be removed by the public if you place them on the rail, then push the car up on the tongue before uncoupling. I would suspect that a second chain between pairs of chocks would allow them to be locked around the wheel; then again a loop of chain just locked around the wheel does pretty much the same thing.
I did a quick Google search, and my first hit has some incredibly cheap prices:
http://www.rrtools.com/trackAccessories ... Skates.asp
I have no affiliation with this vendor.
PostPosted: Wed Aug 31, 2011 2:22 pm
We use rail skates as a safety device where necessary to park equipment on steep grades without derail protection and on locomotives which tend to have weak handbrakes. The locomotive skates are shop fabricated and are slightly lower profile than the commercial products to clear brake rigging and sander hoses.
Alan Maples
Everett Railroad
PostPosted: Wed Aug 31, 2011 3:12 pm
We use skates also. The car blocks will work. Need to park a string of cars against them for longer time storage. Thanks.
