It is currently Mon Oct 12, 2026 11:11 pm
 Post subject: Operating Steam in Roanoke
PostPosted: Tue May 01, 2012 9:38 pm
No, We didn't do a stealth restoration on 611 while no one was looking (yet). But steam is returning to Roanoke on the 12th & 13th.
Scroll down to "Roanoke Rail Fest"
http://vmt.org/visit/calendar.html
http://www.facebook.com/VA.Museum.Trans ... 203304498/
We will be kicking off the event with a whistle blow from 6-8 pm on the 11th. A manifold and steam will be provided, BYOW
Gary
 Post subject: Re: Operating Steam in Roanoke
PostPosted: Tue May 01, 2012 9:51 pm
Word here in NC has it that some particularly loud and distinctive whistles will be coming north. Ditto some of the crew.
PostPosted: Wed May 02, 2012 4:27 pm
You guys should strike up a deal with Strasburg and get 475 down there.
Mark Z. Yerkes
Amateur Rail Historian
PostPosted: Wed May 02, 2012 4:44 pm
If 475 came down we wouldn't want to give it back.....
Gary
PostPosted: Thu May 03, 2012 3:57 pm
Gary, there is a good sized contingent here who have spent enough time in her cab to look at that as the best possible outcome....
Brendan Zeigler
Vice President - CMO
Strasburg Rail Road Co.
brendan.zeigler@strasburgrailroad.com
PostPosted: Thu May 03, 2012 6:40 pm
You know the famous "yellow line" that is usually about 54" above ground level at some theme park rides that has the sign "You must be at least this tall to ride this ride"?? Well, In the enginehouse at SRC, there needs to be a piece of plywood with an appropriate size hole, and the sign "You must be able to crawl through this hole to operate this locomotive".
PostPosted: Thu May 03, 2012 7:01 pm
Brendan, You start working on your boss and I'll start the fundraising (& dieting) down here. Do you think you can talk Linn into a "rent to own"?........:)
Gary
PostPosted: Thu May 03, 2012 7:28 pm
The obvious solution is for the Roanoke folks to come up with a steam locomotive to restore and trade to Strasburg for the 475.
If only someone knew of a good, sturdy 4-8-0 or 2-8-0 in a junk yard somewhere....
PostPosted: Thu May 03, 2012 7:49 pm
If you got 475 there, Virginia would be the 4-8-0 capital of the world. In reality, there's several other N&W 4-8-0 restoration opportunities lying around the state.
PostPosted: Thu May 03, 2012 8:12 pm
It has been rumored that Mr. Moedinger likes Canadian Pacific G5's.....just sayin'... As for other 4-8-0's in Virginia, again that would probably involve the right trading material. At the moment, we're working on the more track & shop space issues (and nothing further will be said so don't ask)
Gary
PostPosted: Thu May 03, 2012 11:08 pm
"You know the famous 'yellow line' that is usually about 54" above ground level at some theme park rides that has the sign 'You must be at least this tall to ride this ride'?? Well, in the enginehouse at SRC, there needs to be a piece of plywood with an appropriate size hole, and the sign 'You must be able to crawl through this hole to operate this locomotive'."--Mark Jordan
Hmm, that seems to confirm the story I've heard about the 475, that it's cab is cramped enough that Strasburg crews have taken to calling the locomotive the "telephone booth."
Hmm, let's see, what would be a good trade--how about that Baldwin Decapod at, where was it, Mid-Continent? Reportedly the engine doesn't quite fit at MC, perhaps because so much other work goes on with the rest of what they have (which is quite a bit). It would join a sister at Strasburg, and SRR would have two identical engines, with the ease of maintenance that comes from standardization.
Now, how to get that engine out of Mid-Continent, specifically what to give to Mid-Continent. . .I'm going to have to get a printing press and some green ink. . .or figure out a winning lottery system. . .
PostPosted: Fri May 04, 2012 2:54 pm
The 475 is a full backhead locomotive with a wide firebox. It makes for cramped quarters. I believe the brake stand is mounted way up on the side of the firebox.
I rode in the "jump seat" on the fireman's side of the 475 in 1995, and recall it was a rather cramped ride.
PostPosted: Fri May 04, 2012 6:45 pm
I think 475 has what is known as a "deckless cab." The Baldwin 2-8-2's at the East Broad Top are similar, as are a number of older Rio Grande narrow gauge engines.
PostPosted: Fri May 04, 2012 10:08 pm
I saw a show on PCN Tours (those of you from PA should know that show) on Strasburg awhile back. Apparently, the reasoning behind the design of 475's cab was due to the fact that the M class 4-8-0's wouldn't be able to fit on some of the N&W's turntables if it had been designed with the cab in a more traditional position, so the cab was built to completely straddle the firebox, thus keeping the length of the engine down.
It's been awhile since I saw that show, so if I have some info wrong, I apologize.
Mark Z. Yerkes
PostPosted: Fri May 04, 2012 10:25 pm
Another possible reason for the design might would be that the M's were basically an enlarged version (with higher speed capability) of the N&W's standard W class 2-8-0's. They were also "deckless", something quite common at the turn of the 20th Century
Gary
