It is currently Sun Nov 22, 2026 10:32 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: C&O 611 images
PostPosted: Fri Mar 22, 2013 12:18 am
whodom wrote:
wilkinsd wrote:
It's an interesting suggestion, given the improved efficiencies of the Worthington system. I wonder how it would improve 614's operation, and fuel consumption.
Plus, you have the perfect place the mount the cold water pump.....
IIRC, the figure usually tossed around during steam was around 10% improvement in power and fuel consumption, plus reduced boiler maintenance as the open feedwater heater helped de-oxygenate the feedwater prior to its introduction to the boiler.
I also seem to recall that there was a corresponding reduction in water consumption, as the exhaust steam became condensed and went back into the boiler in the case of an open system, or was returned to the tender with a closed system (such as the Elesco).
PostPosted: Fri Mar 22, 2013 12:39 am
Stumbled onto something else; photos at Russell around 1968, including photos of 611 (614) and K4 (2-8-4) 2705, which is now in the B&O museum in Baltimore (click on photos to enlarge):
http://wvrails.net/?m=201208
An immense collection of 614 preservation era photos; Ross will no doubt recognize some of the people in them:
http://www.flickriver.com/photos/tags/c ... teresting/
Railroad Picture Archives link, again a large selection:
http://www.rrpicturearchives.net/locoPi ... x?id=21017
PostPosted: Fri Mar 22, 2013 5:38 am
We seriously considered adding a feedwater system back onto the 614 when she went through the complete rebuild in 1979-80. We decided against it basically on the " if it ain't broke don't fix it" rule. Subsequent experience has made us glad we did.
There's no doubt that a properly engineered feedwater system would improve the overall efficiency of the engine and be better for the boiler and if the engine were going into "real" service where a fuel efficiency differential of 5-10% made a difference then it would make sense.
The truth is that with this machine hauling 20-25 passenger cars at track speed she hardly breaks a sweat so it doesn't make sense to go away from the ultra reliable overly capable Hancock 4000's.
Ross Rowland
PostPosted: Fri Mar 22, 2013 1:00 pm
Jeff Lisowski wrote:
I found this picture to be of interest. The caption claims it's during an excursion in 1992 at the B&O museum. I find that hard to believe, as 614 wasn't running then.
Yeah, I saw the B&O museum for the first time and 614 sitting there about then as well. That's exactly where 614 was sitting and the same markings she had then. It was clearly after the ACE tests as the tender markings were for the sponsors in the project.
Lee Bishop
PostPosted: Fri Mar 22, 2013 1:30 pm
The never "ran excursions" with 614 at the B&O Museum.
In 1993 or thereabouts, Rowland & Co. came down to "temporarily" decorate 614 for publicity photos for their planned "21st Century Limited" operation, and fired her up to back her across the street for photo poses. Jim Boyd and I staged some late-night open-flash photos of the occasion. That was, as far as I know, the only time 614 was under steam in Baltimore since the 1980-81 Chessie excursion era.
PostPosted: Fri Mar 22, 2013 1:44 pm
If you could walk into that photo, and walk around to the fireman's side of the 614, she probably would have the plywood "skirting" and other decoration for the 21st Century Limited project.
I saw 614 in Baltimore in the summer of 1995 and she was decorated as such, buth with her 614 guise on the other side.
PostPosted: Fri Mar 22, 2013 1:48 pm
I found out a little more about the Hancock Turbo Feedwater Heaters as used on the 614. Apparently they were also used on the New Haven 4-6-4's and Pennsy's T-1's, and gave problems on both those classes of locomotives. You have to wonder why the C&O would have gone with this system when they'd apparently had good results on previous locomotives with Worthington products.
PostPosted: Fri Mar 22, 2013 2:12 pm
It's amazing what you can turn up on the internet these days. Apparently the N&W tried one of the Hancocks, or at least prepared the drawings to install one on a Y-6 in 1938:
http://www.nwhs.org/archivesdb/detail.php?ID=23801
It looks like quite the plumber's nightmare!
PostPosted: Fri Mar 22, 2013 2:34 pm
Where are the shots of 614 like this? I can't recall ever seeing any...
Lee Bishop
PostPosted: Fri Mar 22, 2013 2:47 pm
My memory has failed, me, but I thought she retained her 614t lettering on one side. Maybe I remember it "ghosting" through the paint job.
http://www.railpictures.net/photo/223170/
Still, she also had a plywood running board skirt on one side.
PostPosted: Fri Mar 22, 2013 6:55 pm
Wow, with a centered headlight!
Most cool, but what about shots with the plywood skirting? I've never been able to find photos of that...
Are there any good shots of the markings on the tender? I like that blue stripe, it's a great look!
Lee Bishop
PostPosted: Fri Mar 22, 2013 8:44 pm
There are some photos of 614 in her blue skirting in this Trainorders thread. Not sure if you can see them if you're not a member. A Google search didn't turn up much.
http://www.trainorders.com/discussion/r ... 11,2328867
David Wilkinson
Salt Lake City, UT
PostPosted: Fri Mar 22, 2013 9:38 pm
Copyright (C) Mike Del Vecchio
PostPosted: Fri Mar 22, 2013 9:52 pm
She looks good with the center-mounted headlight.
Mark Z. Yerkes
Amateur Rail Historian
PostPosted: Sat Mar 23, 2013 8:51 am
I must confess to prefering the center mounted headlight but I've yielded to the vast majority of my crew who prefer the historically correct position.
You can't win 'em all!!
Ross Rowland
