It is currently Sun Nov 01, 2026 6:56 am
 Post subject: Static Friction vs. Kinetic Friction
PostPosted: Tue May 14, 2013 10:55 am
Last edited by Kelly Anderson on Wed Aug 07, 2024 12:05 pm, edited 1 time in total.
 Post subject: Re: Static Friction vs. Kinetic Friction
PostPosted: Tue May 14, 2013 11:30 am
Don't they have sand on British locos? What is all the steam coming out around the drivers? I don't understand everything I see here. Other than very excessive slipping.
Maybe they should put aluminum oxide tires on her and do some rail grinding while they're out.
PostPosted: Tue May 14, 2013 11:36 am
PostPosted: Tue May 14, 2013 12:13 pm
Is that engine superheated, with a dome throttle? It looks like he lost it with the units full of steam; finally decides at 1:25 to open the cylinder cocks and arrests the slip.
PostPosted: Tue May 14, 2013 1:22 pm
They were doing a burnout to get the tires hot for better grip. Just like at the drag strip.
Steam to deliver the sand seems like a bad idea. Always have a wet rail to keep things lubed up. Even worse if you run out of sand.
PostPosted: Tue May 14, 2013 1:29 pm
The British invented wheelslip, and remain the masters of the craft, clearly.
Didn't they recently destroy an engine by overspeed during a wheelslip event?
PostPosted: Tue May 14, 2013 1:52 pm
http://en.wikipedia.org/wiki/LNER_Peppercorn_Class_A2_60532_Blue_Peter
http://www.youtube.com/watch?v=YjsNbzg1UaI
That was nearly 20 years agao now, is that recent? That's 1/10th of the way or so back into the total history of the steam locomotive.
I think this latest video, they were just tired of continuously welded rail, and they are just putting the authentic clickety-clack back in the track.
PostPosted: Tue May 14, 2013 4:54 pm
The more bits and pieces I pick up about tribology, the less I learn I know about it.....not always intuitively obvious.
British practice is a lot of oil lubing everything and steam wet-sanding......I'd imagine they would develop an early and extreme familiarity with wheel slip and how to control it.
