It is currently Wed Jul 29, 2026 11:26 pm
 Post subject: Superheater flue order underway
PostPosted: Mon Jun 17, 2013 3:10 pm
Hello all,
Stathi Pappas at the MRSR is putting together a bulk order for 5 1/2" OD superheater flues. Our minimum order is 950 ft. Cost will be $13.75/ft. We need at least one more locomotive's worth of flues to make the minimum. If you are interested in coming in on the order please PM me or get in contact with Stathi at Mount Rainier Scenic. They are also set up to swage these so you can get them finished at additional cost.
Thanks to all!
Chris Allan
J. Chris Allan
WP 165 Restoration Blog:
http://wprrsteam.blogspot.com
 Post subject: Re: Superheater flue order underway
PostPosted: Tue Jun 18, 2013 9:05 pm
Greetings!
This is a German order?
Cheers, Jason
PostPosted: Tue Jun 18, 2013 9:35 pm
I just received a quote with a 12,267 ft min order (10,000lbs) @ 10.30/ft.
I'll be in contact...
Robert Yuill
historicmachineryservices.com
PostPosted: Tue Jun 18, 2013 9:56 pm
Hey Robert,
I ran into the same issue when searching out flue material for the 1003 two years ago. Almost unbelievable we don't readily have access to such material on this continent....or anywhere in Europe (other than the German mill)...... Without the almost two locomotive minimum order that is.
Cheers, Jason
