It is currently Sat Oct 31, 2026 10:08 am
 Post subject: locomotive valve gear's
PostPosted: Tue Dec 17, 2002 7:55 pm
In today's world,,for those of you who are running steam,,either in the tourist,railroad or the excurison's I have a question which type of locomotive valve gear,,,is the easierest to maintain,,,,,,WALSCHAERTS OR BAKER VALVE GEAR....
cprh1b@attbi.com
 Post subject: WALSCHAERTS *NM*
PostPosted: Tue Dec 17, 2002 10:34 pm
kelly@strasburgrailroad.com
 Post subject: Re: locomotive valve gear's
PostPosted: Wed Dec 18, 2002 11:05 am
The Baker valve gear has all pivotal joints and is much easier to maintain than Walschaerts. The link and link block of the Walschaerts are exposed to the elements and subject to ware where the Baker's working surfaces are all round and typically used sealed needle bearings.
Roger Mitchell
Master Mechanic
Fort Collins Municipal Railway
n0mcr@netzero.net
PostPosted: Wed Dec 18, 2002 2:24 pm
Walschearts is far simpler, has fewer moving parts, is easier to set and easier to keep set, and much easier and cheaper to maintain.
PostPosted: Tue Dec 24, 2002 12:30 pm
> maintain.
Actually setting instructions for the Walschearts and Baker valve gear are exactly the same and it is much easier to machine pins and bushings than it is to re-machine the radius of the link and manufacture a new link block of the Walschearts. Cutting the radius' on the Walschearts requires a mill with a large rotary table. I know that because I have done it many times. Making renewal parts for the Baker valve gear only requires a lathe. The Baker valve gear also runs much longer between overhauls than the Walschearts. Thats why many of the later steam locomotives had them. The Baker gear may look more complicated, but is not.
Roger Mitchell
Master Mechanic
Fort Collins Municipal Railway home page
n0mcr@netzero.net
