It is currently Mon Oct 12, 2026 11:49 am
 Post subject: Six wheel trailing trucks
PostPosted: Thu Mar 13, 2003 5:29 pm
I know that the C&O and Virginian 2-6-6-6's had six wheel trailing trucks. But I believe that there may have been an earlier application of a six wheel trailing truck on a locomotive (perhaps PRR?) Does anyone know what locomotive first carried a six wheel trailing truck, who built it and when?
Thanks.
Les Beckman (Hoosier Valley Railroad Museum)
midlandblb@cs.com
 Post subject: Re: Six wheel trailing trucks
PostPosted: Thu Mar 13, 2003 5:35 pm
Pennsylvania's steam turbine was a 6-8-6.
> when?
> Thanks.
frisco1522@earthlink.net
PostPosted: Thu Mar 13, 2003 6:07 pm
But the S-1 was earlier, and it of course had a six-wheel trailing truck (6-4-4-6). I assume you're asking about "normal" locomotives; a large number of suburban tank engines had six-wheel trucks under the tender. The NYC had big 4-6-6Ts that I think look like a J that was telescoped in an accident.
It's really too bad the S-1 wasn't preserved!
PostPosted: Thu Mar 13, 2003 6:40 pm
Les -
PRR's S1 6-4-4-6 duplex was built in 1939 by Altoona, two years before the first H8 for C&O. I believe its design was a joint effort between commercial builders and PRR.
PostPosted: Thu Mar 13, 2003 10:51 pm
> Les -
Dave (and Randall and Don):
Thank you very much. The Pennsy S-1 duplex is the locomotive I was trying to think of. Appreciate your help!
midlandblb@cs.com
 Post subject: Re: Six wheel passenger train trucks
PostPosted: Fri Mar 14, 2003 12:37 am
And that brings up a question anout another kind of six wheel truck.
I just read about a 3 axel passenger car truck that is supposed to weigh 11 tons. That would be 22,000 pounds for one truck; could this be right? Are/were they talking about the pair of trucks on the passenger car?
ted_miles@nps.gov
PostPosted: Fri Mar 14, 2003 10:31 am
A three axle outside swinghanger truck with large central bearing is a massive piece of steel. It's been awile but I think that a disk brake wheelset with bearings and boxes weighs close to 2 tons alone. So 11tons for the complete truck is not out on hand I think that the UP's 6wheel, OSH central bearing truck had a capasity of 90,000 pounds.
> car?
pfdx@aol.com
PostPosted: Fri Mar 14, 2003 12:50 pm
Paul,
Tahnks for the info.
I am glad I don't have to pick up any of those parts and pieces!
ted_miles@nps.gov
PostPosted: Fri Mar 14, 2003 6:46 pm
> Paul,
Actually, that's a bit on the light side. By actual measurement, while being lifted by a hydraulic crane with a strain gage, typical Pullman heavyweight trucks are 13 tons each. This was confirmed in 1991 when RMNE moved 5 heavyweights out of Jim Bradley's backyard in Stonington, CT. The truckless body of sleeper "Breslin Tower" weighs 57.5 tons. The other cars were slightly lighter.
hpincus@mindspring.com
