It is currently Mon Oct 19, 2026 9:40 am
 Post subject: Gyrolight parts
PostPosted: Mon Jan 16, 2017 9:34 pm
I am currently working on restoring the gyrolight our musuem acquired. When we received it, the interior was rattling around (not a good sign). I did a brief visual inspection and found a broken piece on the inside from the body and the support bracket had been cracked. Today I finally dug into the light and found that the bracket that was broken, is in fact part of the entire body casting. From the light weight of the casting, I'm assuming it is aluminum. My question is what, if any, parts availablity is there for these lights? Second, can the aluminum casting be "welded" in some fashion? TIA.
Gary R.
SA, TX
 Post subject: Re: Gyrolight parts
PostPosted: Mon Jan 16, 2017 10:55 pm
There are aluminum rods on the market that will allow welding aluminum with a propane torch. The secret is getting the pieces hot enough to accept the rod without the piece melting into a bigger mess. You can locate a commercial welder nearby that can do the job if there isn't a person in the group willing to try. I suggest welding together the bottoms (or tops) of soda cans for practice before messing up a good light repair job. Make sure the soda cans are full so as to act as a buffer to too much heat.
It is a dirty trick to weld the soda bottoms: BUT, lots of fun to watch an unknown trying separate the cans (I love doing it).
Harry Nicholls
Harry Nicholls
PostPosted: Tue Jan 17, 2017 2:36 pm
It is a dirty trick to weld the soda bottoms: BUT, lots of fun to watch an unknown trying separate the cans (I love doing it)."
It also seems like a dirty trick to have the unwary practicing thin-wall aluminum welding with pressurized soda in the cans...
PostPosted: Tue Jan 17, 2017 3:41 pm
If nobody in your group has a decent amount of welding experience, I would suggest sending it out to a qualified welding shop in your area. Aluminum is one of the more difficult metals to weld, and it being thin only makes it that much more of a challenge. Also, since aluminum doesn't glow when hot, to an inexperienced person it can melt almost without warning.
I would echo that if you don't feel comfortable welding aluminum, find someone who does and can.
PostPosted: Tue Jan 17, 2017 7:34 pm
Absolutely agree.
And the correct term is Gyra-Lite if it's a Pyle-National product.
PostPosted: Tue Jan 17, 2017 9:14 pm
"It also seems like a dirty trick to have the unwary practicing thin-wall aluminum welding with pressurized soda in the cans..."
Well, the welding of "pressurized" soda cans has not been a problem as the heat sink allows the air in the can to escape first before the soda spurts. I have never had that problem, even on my first try. If you get a leak, just use that can as your next experimental weld. Then, try the others.
Harry
Harry Nicholls
PostPosted: Wed Jan 18, 2017 11:44 am
You know, this discussion has gotten way off base... We don't even know that the light housing IS aluminum, it may well be Zamac (zinc alloy, typically die cast). Take it to a welding shop, preferably one that specializes in non-ferrous metal repairs, before you just blow a hole in it.
