It is currently Sun Oct 25, 2026 5:05 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri May 25, 2018 10:24 am
Judging from Google aerial photos, those two freight cars were in a line of equipment that also included two old "Bridge cars" and one of two extant Baldwin-Westinghouse Class S steeplecabs. I wonder if those are on the scrap list.
Frank Hicks
Hicks Car Works
PostPosted: Fri May 25, 2018 10:35 am
Who are you calling "odd"?
PostPosted: Fri May 25, 2018 12:00 pm
Good stuff as always from your crew! I am always amazed at the craftsmanship of what you do at Strasburg.
PostPosted: Fri May 25, 2018 1:22 pm
Once again thank you for your updates and photos.
Question about the old Porter boiler. Just how old is it that boiler design? Appears to have the steam done right over the crown sheet like many of the very old Civil War boilers? Just struck me as odd when I saw the picture. That is one large hole that far back. Or am I missing something obvious? Happens a lot but I just had to ask. Or is this just a different design that I am not familiar with?
Was looking at a picture recently from I think the 1920s of a boiler on a flat car that had the steam dome in same place. We all agreed that this particular boiler was not a railroad locomotive boiler do to a number of inconsistencies. Now this large hole in similar place has me wondering. Obviously I am not a boiler guru.
Regards, John.
PostPosted: Fri May 25, 2018 7:58 pm
Kelly,
Thank you for the very interesting report and photos.
The PRR flat car looks like a model F30a? Many years ago a gentlemen I knew, built an exact replica in S scale in styrene. He became obsessed with the project and the detail and craftsmenship was phenomenal. As I recall he won an award at one the PRRT&HS annual meetings. I believe he was a dental tech or assistant. His meticulous attention to detail really came out to replicate the one-piece casting. He also researched prototype cars to accurately reproduce it in miniature.
Great find!
Sincerely
Randy
PostPosted: Sat May 26, 2018 10:22 am
Frank,
I have it on good authority that the steeple cab locomotive was, indeed, cut up.
Nick
PostPosted: Sun May 27, 2018 11:53 am
Kelly Anderson wrote:
News! News!!
We completed our work on Silver Dollar City #14’s running gear. It is now in Branson being mated to its new boiler. Here are new light weight pistons for #14. Adding 3/8” plates to each side, held in place with staybolts will complete the pistons.
Kelly, would you please provide more detail about the plates and their attachment?
PostPosted: Sun May 27, 2018 8:32 pm
I wonder if the URTX car is actually an insulated boxcar, as I do not see hatches on the roof. IRM recently scrapped a similar car in a little bit worse condition.
I suppose it is possible that this car may have had advertising for some company, under several layers of paint.
PostPosted: Sun May 27, 2018 9:45 pm
Olin -
Yes, I think that URTX 26671 is more likely an insulated boxcar rather than a reefer. Either way, it's a nice save.
As for Randy Musselman's thought that the flat car might be a Pennsylvania F30a class car, the 1,500 PRR F30a's were numbered 473765-475264, so that puts number 474265 into that series.
Both cars are great additions to the Strasburg roster and will look wonderful on future vintage freight trains.
PostPosted: Sun May 27, 2018 11:16 pm
Les Beckman wrote:
Olin -
It's a 1931 built ice reefer that was rebuilt as an RB (Refrigerator, Bunkerless essentially an insulated boxcar) quite late in life. The plug door is not original to the car... very 1960ish.
PostPosted: Mon May 28, 2018 12:48 pm
Not trying to get off topic of the great works of the Strasburg RR Shops, but recently saw this older picture of a boiler on flat car. I thought the picture was fabulous to look at, as many others did too. The location of the steam dome confused me. Then the picture of the Porter boiler going under repair at the Strasburg shops with what seems a similar design. Back channel I was told that this type of steam dome location was not nearly as rare as I thought. Was under the impression that the "big hole" on top of the crown sheet would be a source of weakness so I never questioned it further and accepted this as "undeniable fact". Wrong once again or is that called learning? Anyway thought I would share the photo link so maybe my question and confusion might make sense? The two boilers in question are quite different in many ways but the location of the steam dome appears to be a similar design. I really like the overhead crane in this picture. Regards, John.
http://www.shorpy.com/node/23403?size=_original#caption
PostPosted: Mon May 28, 2018 2:16 pm
Last edited by Kelly Anderson on Wed Nov 27, 2024 3:17 pm, edited 1 time in total.
PostPosted: Mon May 28, 2018 6:07 pm
Many portable steam engines (not locomotives) such as Farquhar, Frick, Enterprise, and others used the "dome over firebox" design. The wrapper sheet is rolled in the traditional manner, and there is NO "big hole" under the dome. The staybolts from the crown sheet pass through larger oversize holes in the wrapper sheet up into the dome, where they attach to the dome top head. The wrapper sheet under the dome is called a "neutral sheet" as it has steam pressure on both sides of the sheet. The steam produced by the boiler travels through the oversize holes in the neutral sheet up into the dome.
There is no access inside the boiler, and there is no throttle valve in the boiler (of portable steam engines) as it is in the exterior piping.
PostPosted: Mon May 28, 2018 10:41 pm
Thank you both for the interesting information. I had no idea about the "neutral sheet" or how it worked. And the older design Porter is a pretty fascinating picture as well. Really appreciate you guys taking the time to educate.
Regards, John.
PostPosted: Tue May 29, 2018 1:05 am
There are many words of praise for what we see. . .and seeing what's going on elsewhere, including what Strasburg has been doing for Florida East Coast's 148, there is simply no praise that can be added!
