It is currently Sun Oct 18, 2026 2:52 pm
 Post subject: Plus gas still the best?
PostPosted: Fri Dec 21, 2018 8:29 am
Have to buy some penetrating/releasing fluid. :(
Plus gas used to be good,anyone got any recommendations? I want to get cash advanse, found good website with it.
Not keen on aerosols due to wastage,even better would be any`home made`recipes,if there are such things.
 Post subject: Re: Plus gas still the best?
PostPosted: Fri Dec 21, 2018 8:42 am
Kroil and WD 40can be bought in gallon jugs. Not sure about PB Blaster.
PostPosted: Fri Dec 21, 2018 9:24 am
A 50 / 50 mixture of acetone and automatic transmission fluid works better than most commercial products.
Keith
PostPosted: Fri Dec 21, 2018 2:42 pm
+1 on Acetone/ATF
PostPosted: Fri Dec 21, 2018 5:34 pm
Yup on the PB Blaster. I have one out in the shop.
Brian
Online
PostPosted: Fri Dec 21, 2018 5:55 pm
Which kind of Automatic Transmission Fluid? Type F for Ford, General Motors, Dollar General, or what?
PostPosted: Fri Dec 21, 2018 5:59 pm
https://youtu.be/YeTNXbDbHcM
PostPosted: Fri Dec 21, 2018 6:06 pm
Another good one to watch: https://www.youtube.com/watch?v=xUEob2oAKVs
PostPosted: Fri Dec 21, 2018 6:12 pm
Dexron GM
PostPosted: Fri Dec 21, 2018 10:28 pm
I highly recommend Kroil, while WD-40 is good Kroil is way better.
On a wooden Flanger we are restoring Kroil loosened a whole bunch of 50+ year-old rusted nuts and bolts that nothing else could get.
Greetings from Alberta
-an Articulate Malcontent
PostPosted: Sat Dec 22, 2018 12:24 am
ANY type, whatever is cheap. There isn't a lot of difference between them. In fact, hydraulic oil probably will work the same, as there isn't much difference between ATF, hydraulic transmission fluid, and straight hydraulic oil, beyond the additive packages added to the base stock.
BTW, type F is barely for Ford anymore. They abandoned that 35 years ago for the Mercon fluid which is sold as Dexron/Mercon fluid.
