It is currently Mon Sep 28, 2026 3:47 pm
 Post subject: These two survived
PostPosted: Sun Jun 22, 2003 8:49 am
Just a link to some old drawings of compound steam locomotives on the Railroad Extra website. The SP Mogul below survives today at Dunsmuir, Cal., long ago converted to a simple locomotive.
http://www.railroadextra.com/loco06.Html
ryarger@rypn.org
 Post subject: Re: These two survived
PostPosted: Sun Jun 22, 2003 9:06 am
And this one is at Ashland, Wisconsin.
http://www.railroadextra.com/loco07.Html
ryarger@rypn.org
 Post subject: Surviving Compound Locos
PostPosted: Sun Jun 22, 2003 11:30 am
There are two formerly compound locomotives at the Museum of Transportation in St. Louis. These are Lake Street Elevated Railroad 0-4-4T #9, "Charles H." and Wabash 2-6-0 #573. Both are products of the Rhode Island Locomotive Works. The first was built in 1893 and the second in 1899. Both were cross compound types when built and later converted to simple locos.
rdgoldfede@aol.com
 Post subject: 1727 today *PIC*
PostPosted: Sun Jun 22, 2003 6:02 pm
Converted in the Sacramento shops to simple and added superheat. Some of us still dream that she may once again run somewhere.
S'
David Dewey
Friends of the 1727
djdewey@cncnet.com
 Post subject: Klondike Mines Railway #3
PostPosted: Sun Jun 22, 2003 7:22 pm
As far as I know, the only non simpled Vauclain compound conventional locomotive in existance is Klondike Mines Railway #3, a 2-8-0 narrow gauge engine at the Dawson City Museum, Dawson City, Yukon Territory, Canada. It was set aside when the railway closed in 1913 and never ran again.
Tom
ironbartom@aol.com
 Post subject: Re: Surviving Compound Locos
PostPosted: Sun Jun 22, 2003 9:09 pm
About the only non-articulated compounds that still survive in their original configuration in this country are the Manitou and Pikes Peak rack locomotives, one of which is still operational.
Roger Mitchell
Master Mechanic
Fort Collins Municipal Railway
n0mcr@netzero.net
 Post subject: Re: Klondike Mines Railway #3
PostPosted: Sun Jun 22, 2003 10:05 pm
Thsi is likely one of the most overlooked and unknown engines in the western hemisphere. It gets my nomination for the most significant, unaltered turn of the century locomotive left in North America.
What is its actual physical condition?
lorija799@aol.com
PostPosted: Mon Jun 23, 2003 11:43 am
The engine and three other locomotives are housed in a protective building in a state of arrested decay. I get my information from the book The Bonanza Narrow Gauge Railway by Eric L. Johnson, 1997. The three engines of the Klondike Mines Railway had been stored in their engine house until the second World War when the White Pass & Yukon tore it down to get to the #4 and spare parts.
Tom
ironbartom@aol.com
 Post subject: Re: Surviving Compound Locos *PIC*
PostPosted: Tue Jun 24, 2003 1:46 am
What about the Baldwin 60000 in the Franklin Institute in Philadelphia. She's even in great shape!
I don't know much about steam locomotives, but the description says:
"As a means of obtaining the higher expansion necessary to give economy with steam of 350 pounds per square inch, Locomotive 60,000 was designed with three cylinders compounded, the high-pressure steam being first admitted to the middle cylinder. After expansion there, the steam passes through the receiver in the cylinder saddle to the two outside cylinders where further expansion takes place."
I happened to think of the 60000 when I was browsing the internet and saw this photo:
http://www.respree.com/cgi-bin/SoftCart ... ?E+scstore
Here's some a link from the Franklin Institute:
http://www.fi.edu/tfi/exhibits/trainfactory/about.html
JimE
Baldwin 60000
jrevans@accusort.com
PostPosted: Tue Jun 24, 2003 1:40 pm
60,000 has had some pretty good running gear wear due to moving daily for 70 years, but this revolutionary locomotive is certainly worth studying.
Don't forget Union Pacific 4-12-2 9000 at the Los Angeles Co. Fairplex, Pomona, CA. How about finding some really heavy straight track!
Some of these other engines may be compound:
Three Cylinder Steam
mjanssen@sunvalley.net
PostPosted: Wed Jun 25, 2003 11:36 pm
The UP 9000 is a three-cylinder simple locomotive, not a compound.
bruceman@stargate.net
PostPosted: Thu Jun 26, 2003 5:00 pm
Actually, Bruce, you are wrong. The 9000s were arranged with the center cylinder high pressure, outside cylinders low pressure. The ratio between high pressure and low pressure circuts was 2.066. Resuperheat for LP cylinders was not used.
I suggest you reread Kratville's first book on the 9000 before making any more claims.
PostPosted: Fri Jun 27, 2003 8:29 pm
Actually Matt you are wrong. Before quoting Kratville's book you had best look in a loco cylp. I think 1930 would be a good year. I will look it up if you need help after the weak end. NEVER take kratville as being right. regards bb
staybolt2@netscape.net
 Post subject: stats and background info
PostPosted: Sat Jun 28, 2003 7:09 am
A book I have and steamlocomotive.com both show that the 9000's were simple expansion with the outside cyls @ 27 x 32" and the inner one 27 x 31" - the only one difference being one inch in stoke.
The third cylinder was added because the belief at the time was that there would be too much piston thrust from two pistons for the desired design. The tests indicated that the 9000's could handle the same drag as the Mllets at higher speeds with less fuel consumption.
Ray
UPRR 9000's
 Post subject: Re: stats and background info
PostPosted: Sat Jun 28, 2003 9:59 am
> consumption.
> Ray
Yes ray is right most of the time he is. I found the info on the UP 9000. In the 1930 loco cylp. pg. 260-262 look it up for your self. Why is it we are so lazy we can't take the time to look up the real deal. And we just say what we think it must be. Hint read a good book to night. regards bb
