It is currently Mon Oct 26, 2026 12:51 am
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: N&W 611 To Visit Strasburg RR via NS in Sept./Oct
PostPosted: Wed Aug 07, 2019 4:17 pm
Last edited by Kelly Anderson on Sun Sep 29, 2024 4:50 pm, edited 1 time in total.
PostPosted: Wed Aug 07, 2019 7:03 pm
Kelly Anderson- How’s the 475’s 1472 coming along?
Matt Helton
Goose Creek Railroad
Bristol, Virginia
https://www.facebook.com/GooseCreekRR
PostPosted: Thu Aug 08, 2019 12:35 pm
Break out the "DON'T ASK WHEN!!!" chalk/paintstick..... <:-D
PostPosted: Thu Aug 08, 2019 12:45 pm
475 will be done sometime between now and September 21st...
Kelly, do you know the date that 611 will start her trek up? Will it leave August 18th after the Fireup on the 17th? I am setting a goal to try and chase it up to Strasburg once it reaches the PA/MD boarder...
PostPosted: Thu Aug 08, 2019 1:55 pm
Last edited by Kelly Anderson on Sun Sep 29, 2024 4:49 pm, edited 1 time in total.
PostPosted: Thu Aug 08, 2019 1:57 pm
PostPosted: Thu Aug 08, 2019 2:01 pm
Thanks for the pictures Kelly. Always fascinating to see the engines in various stages of rebuilds.
Looking forward to the event.. boxcars or no boxcars! :)
PostPosted: Thu Aug 08, 2019 4:01 pm
NS has formally invoked the 'cone of silence' on the move, fearing too many trespassers, chasers, etc.
Which means that the railfan network will still broadcast it, but it won't come from here, not Strasburg, so don't expect Kelly to be the source, or more accurately, the leak.
Just show up at Strasburg when it's actually there and running. Oh, and bring money to support the cause.
PostPosted: Thu Aug 08, 2019 4:18 pm
Yes sir! I will ask no questions and do as you say sir!
PostPosted: Fri Aug 09, 2019 7:36 am
Kelly Anderson wrote:
And the new right rear driving wheel center has been painted and the wheel set installed.
Perhaps a silly question, but this photo causes me to ask, how does one get the drivers aligned when you ready to install the rods?
Thanks in advance.
Bob
PostPosted: Fri Aug 09, 2019 9:24 am
One cannot "sneak" a 400 ton J out onto the railroad without someone seeing it. Of course it could leave dead-in-tow, rods off, but at some point someone will see it pass, and then everyone within a couple of hundred miles who cares and can get away will be off to the races. But that number will be greatly limited by the last minute nature of knowing about the move, which is really the best NS could hope for. Keeps the more dangerous "daisy pickers" away. Hopefully those who do find out and go out are the fans who know railroad etiquette and how to be safe.
PostPosted: Fri Aug 09, 2019 10:43 am
Rumor on the street is that Scott Lindsay and his team have fabricated some lightweight panels to attach to the sides of the boiler & tender that will make the 611 appear to be just another auto rack car and thus move without notice???
Could be true !!
Ross Rowland
PostPosted: Fri Aug 09, 2019 11:00 am
Back in the day, you could make such a move and only someone who happened to be standing aside the tracks would know about it.
I grew up along the SCL in North Florida and once, there was a special unannounced move of S&A 750 for the Southern Steam program through the area. Nobody knew about it except fans who lived near enough the tacks to hear it go by and only one managed to catch up to it that I was ever aware of (without camera as he had to actually run to the car and take off west bound in pursuit).
These days, you could send the Bat Signal to the world right away and people would be all along the right of way to see it.
Lee Bishop
PostPosted: Fri Aug 09, 2019 11:47 am
Could be true !!
Ross Rowland
Ross, is that how you move the 614 around when needed? ;)
PostPosted: Fri Aug 09, 2019 11:51 am
Thanks in advance.
Bob
What you are describing is called "quartering." Some links below may help out.
http://www.wwfry.org/pics/SteamLocomotiveQuartering.pdf
This is not as good a video as I would have liked--I wish more was shown as to how the tools and other devices were used--but this slide show for a live steam model shows this fellow's approach. The main difference in a small model like this and the real thing is the size of parts, tools, and the amount of hydraulic force you use to press drivers onto axles and crank pins into the wheels.
https://www.youtube.com/watch?v=dXGRVPkbyyQ
This is for press fit only. While this was often used, drive wheels and axles were also "keyed." This was having slot in the wheel and a matching slot in the axle, into which was inserted a key to maintain the alignment. If you look at the drivers on the 475 in the photo, you can see the keys between the wheel hubs and the axles. Various forms and shapes of keys and their slots (called "key ways") make them resistant to working out.
