It is currently Sat Aug 22, 2026 2:08 pm
 Post subject: Golden Glow headlight restoration
PostPosted: Tue Sep 07, 2021 10:45 pm
What I Have:
18" Golden Glow headlight, I believe is from a Russell plow. Originally yellow, no hood, and never had numbers on the windows.
I am looking for pictures, or information, on how the reflector is mounted inside the housing. I have threaded tabs, but no reflector. I believe there should be some sort of mounting ring that I am missing.
I am also looking for a reflector and lens. Reflector may be 17".
Thanks in advance
E
 Post subject: Re: Golden Glow headlight restoration
PostPosted: Tue Sep 07, 2021 11:11 pm
Weren’t those golden glow reflectors made of uranium glass? That’s gonna be hard to find unless someone has one squirreled away.
PostPosted: Tue Sep 07, 2021 11:52 pm
Within the past few months there was a thread with a similar question, I think for a Golden Glow headlight.
PostPosted: Wed Sep 08, 2021 11:22 am
Yes, there was a topic on this very same light that I believe was in classifieds. But between the small topic derailments, some of comments that were starting to surface, and the history lessons emerging (which was valuable info) I decided to repost in the interchange. I do not want to coble this together. I would like to restore it as it should be, with the proper reflector and lens. Maybe the parts do not exist. If not then I will go a different route. I have never seen an 18" headlight before so I like the fact that it is unique, which may very well kill the whole project.
E
PostPosted: Thu Sep 09, 2021 10:01 pm
I may have found a source for the lens and reflector. I need to know the approximate curve in the lens (the depth of the center of the lens from the inside) and any info on the distance of the bulb filament from the hole in the reflector. Measurements from a 16" light would get me close and a 14" may help.
E
PostPosted: Fri Sep 10, 2021 9:46 am
Here is the link to the last thread on this.
viewtopic.php?f=1&t=45527&hilit=golden+glow
It seemed from that discussion the lamp had a clear lens with a parabolic reflector. If so once you have the diameter and focal point established the reflector shape can be derived by mathematics.
PostPosted: Sat Dec 18, 2021 11:20 pm
Could this work?
https://discoverlivesteam.com/discoverf ... /index.htm
I am in no way shape or form associated with the seller but it appears in the dimensions there might be a similar measurement to what you are looking for on the headlight. Perhaps this person was referring to the side with the lense when they listed the X17 in the 21X17X19? Seller has already confirmed the bowl is Uranium glass so it might be worth a shot.
PostPosted: Mon Dec 20, 2021 10:25 am
That headlight on "Discover Live Steam" is from an Illinois Central MU car. The offset is to conform to the curved end of the roof. DL&W MU cars had similar headlights, with the number boards offset to the top of the light.
PostPosted: Mon Dec 20, 2021 4:05 pm
And those MU headlights are 14".
G.
PostPosted: Wed Dec 22, 2021 4:53 pm
For what it's worth, "Golden Glow" was a trademark of the Electric Services Supply Company ("ESSCO") of Philadelphia, although Pyle and C-H also supplied uranium glass reflectors. Uranium for industrial processes became unobtainable upon commencement of the Manhattan Project, when the Government pre-empted all the supplies of it, eventually placing them under control of the AEC (Atomic Energy Commission) in 1946. The AEC has since been converted into two other alphabet soup-lettered Government agencies.
The reflectors are parabolic in cross-section, and the ESSCO-made ones have a keystone emblem etched on the silvered side of the glass near the rim. The theory was that the yellow/green color projected without causing a lot of glare. If you watch the sun disappear over the horizon, there is a flash of this same yell/green color, which is an effect of refraction as the sun sets (or rises) https://www.phenomena.org/atmospheric/greenflash/
The reflectors can be re-silvered, after which they look brand new. If yours has the Keystone (or any other) emblem, be sure the mirror silvering company doesn't polish it away during re-silvering -- it will stand out quite noticeably.
PostPosted: Thu Dec 23, 2021 4:37 pm
I would have thought the reflectors were silvered on the backside and coated with a protective coating that would both protect the fragile silver and keep it from tarnishing. Thus the light from the source would travel through the glass of the reflector, picking up the color of the glass.
If that's the case, I wouldn't understand someone removing old silver by grinding it off, but using a solvent to remove the protective coating. If there is any silver left, it should come off pretty easy with a bit of rubbing. Grinding could also damage the polish of the glass surface.
If you want to silver the reflector yourself using closer to historical methods, the process isn't that hard but does require some learned art. This company (no connection other then I've been a customer) has the materials and training videos:
https://angelgilding.com/
If you want something more durable, there are companies that will vacuum coat optics with everything from aluminum (durable and cheaper) to gold. Some might even be able to coat an interface coating on a modern piece of glass that would replicate the gold color of the glass, but these days that might be easier to do by trying some LEDs.
Finally, there is some science behind using a yellow/green color. That is the range of wavelength the human eye is most sensitive to at night/when dark adapted. I have to guess the old timers figured this out through trial and error or by accident.
Bob
PostPosted: Tue Dec 28, 2021 3:28 am
Correct.
Yes, the old silvering is removed chemically, buy there is still some polishing involved, mainly to remove all traces of the backing paint.
> If you want to silver the reflector yourself using closer to historical methods, the process isn't that hard but does require some learned art. This company (no connection other then I've been a customer) has the materials and training videos: https://angelgilding.com/
The slightest amount of grease or oil on surface to be silvered will cause the process to fail.
Having had several reflectors re-silvered, and trying to do so myself (and failing), I recommend finding a supplier who can silver mirrors.
PostPosted: Thu Dec 30, 2021 3:07 pm
I recently had a 100+ year-old mirror resilvered by Frank at Walter's Mirror. Frank and his associates are courteous, professional, and enthusiastic about the work. They delivered a quality product at the agreed to price and in the agreed to timeframe. He has a pretty large set up so he may be able to do the reflectors. When I was there picking up he had some large metallic items that he had just nicely resilvered sitting on the bench waiting to be packed for shipping. They looked to be some sort of electrical contacts. Contact info below. Also has a website.
Frank
Walter's Mirror
1625A Cody Ave.
Ridgewood, NY 11385
718-366-0777
sales@waltersmirror.com
PostPosted: Sun Jan 02, 2022 5:10 pm
Last edited by Kelly Anderson on Thu Aug 29, 2024 4:43 pm, edited 1 time in total.
PostPosted: Thu Jan 06, 2022 7:59 pm
For what it's worth, I just ran across this:
https://www.youtube.com/watch?v=RGw6fXprV9U
His results aren't "green enough", so I suspect that some iron was added to the mix "in them days". Because of their relatively large size, alpha particles can be stopped by two sheets of paper or about 2 feet of air, but beta particles and in particular gamma rays are far "smaller" and more energetic, requiring shielding (lead or several inches of concrete). So this isn't something to try at home. Besides, ordering uranium compounds of any kind will flag you with the homeland security folks.
