It is currently Tue Sep 29, 2026 8:21 pm
 Post subject: Re: boiler studs
PostPosted: Mon Jan 19, 2004 12:32 pm
> You can drill through a busted off stud and
> heat it up, then squirt water down the hole
> to shrink it out of its attatchment. Once it
> cools enough not to distemper a tool, use an
> easy out to remove the stub.
> dave
I have done it alot. However if its near a riveted seem or staybolt I heat yhe stud red hot and let it cool off, no quench. You can also put some kroal on it when worm and wait for it to work . Say 10 min. or so. Most of the time that will work. bb
 Post subject: Re: Nice GG1
PostPosted: Mon Jan 19, 2004 12:59 pm
> I do not know a lot about these locomotives,
> but the quill drive is a type of system
> where the motor is basically constructed
> around the axle and the axle in effect is
> the armature shaft. There is no way you
> could change motors or replace AC with DC or
> use 'smaller' motors as one earlier post
> suggested.
Isn't "the axle in effect is the armature shaft"
what the Milwaukee Road "Bi-Polar" and some other
locos of that earlier era used?
The "Quill" is a hollow cylinder with the axle
running through it. Prongs (quills?) on the ends
of it engage spring cushioned "cups" inserted
into the driving wheels. The motor armature can,
but does not have to, use the "quill" as its core.
Wasn't the advantage of the GG1 that it used 12
small motors, possibly like the ones in PRR MU
cars? Each pair turned gears mounted on a hollow
quill (12 motors, 6 driven axles). Is it
possible that the competing R1 (4-8-4), only one
of which was built because "Old Rivets" tested
better, was the electric loco with the large
motors that you mentioned?
> SD90MAC to power an NJT cab car???? DEFINITELY
APPLES AND ORANGES. <
But probably possible, as many modern diesels are
backwards compatable for many generations.
Thanks for expaining about your loco's
transformer. Now, when will your "Little Joe" be
running?
TyburnRR@cs.com
 Post subject: New steam on the mountain
PostPosted: Mon Jan 19, 2004 11:23 pm
Impressive new cog engines, I think in Switzerland.
http://abpr.railfan.net/abprphoto.cgi?june03/06-14-03/BRB_1.jpg
ryarger@rypn.org
 Post subject: Re: New steam on the mountain
PostPosted: Tue Jan 20, 2004 6:56 am
> Switzerland.
Read more at their website:
http://www.brienz-rothorn-bahn.ch/e.html
More technical details on the engines can be found at my website at the link below:
New Steam from Switzerland
whodom2001@yahoo.com
 Post subject: CHS Geo. Loop RFI text
PostPosted: Sun Apr 04, 2004 11:38 am
PDF file--Very interesting reading. Draw your own conclusions.
CHS Geo. Loop RFI
eledbetter@rypn.org
