It is currently Sat Oct 24, 2026 10:21 am
 Post subject: Extra locomotives on coal trains
PostPosted: Thu Apr 29, 2004 8:01 pm
This isn't a preservation oriented post, but...
For the last six months or so, every Chicago bound UP coal train I've seen has an additional locomotive at the end (usually an ex-SP unit). The same setup is on the empties as they head back west. I'm sure this has something to do with braking. Is this practice unique to UP, or is it a new regulation that other major railroads have to adhere to as well?
mckay1995@comcast.net
 Post subject: try www.trainorders.com
PostPosted: Thu Apr 29, 2004 8:15 pm
you will have your answer in 15 minutes!
Jim
Jim@psrm.org
 Post subject: Re: Extra locomotives on coal trains
PostPosted: Fri Apr 30, 2004 10:45 am
> but...
It is called Distributed Power, usually refer to as DPU. You have all of the benefits of a rearend helper but it is controlled by the engineer on the lead unit. It also saves running the power around to the other end if the terminal point (say a coal unloading facility) does not have a balloon track to turn the train. Push-pull freight trains.
Don C.
http://www.261.com
milw261@sbcglobal.net
PostPosted: Thu May 06, 2004 10:22 am
> freight trains.
> Don C.
UP says it also benifits in better braking BNSF does it to.
wooly421@charter.net
