It is currently Sat Sep 26, 2026 12:39 pm
 Post subject: Tool time: Staybolt taps needed
PostPosted: Tue May 22, 2001 3:18 pm
Am in need of 1 inch and 1.25 inch 12 pitch staybolt reamer/taps. Need not be in original packaging, although it would be helpful if they still cut accurate threads. Also probably need other tools I dont even know I need yet, so let me know if you have a list of steam tools for sale/swap.
billc@us.ibm.com
 Post subject: Re: Tool time: Staybolt taps needed
PostPosted: Tue May 22, 2001 3:27 pm
What are you working on? Yes, I know its a boiler :)
Richard
richard.s.wilkens@boeing.com
PostPosted: Tue May 22, 2001 3:34 pm
> boiler :)
> Richard
Sorting out ex NY Shipbuilding #17 Vulcan 0-4-0T, which has a few cracked staybolts.
billc@us.ibm.com
PostPosted: Wed May 23, 2001 8:31 am
Two thoughts:
First, 1.25" dia. staybolts seem a bit large for an 0-4-0T. Typically staybolts start out small (sometimes 7/8" dia.) and are replaced by the next largest size each time they are renewed, up to a point, generally 1-3/16" for small locos. Any bolts larger than 1-1/16" generally have a reduced body so the bolt bends rather than twisting at the sheet and loosening at or eventually cracking the sheet.
Second, Steve Butler at the Kettle Moraine Railway had some staybolt taps for sale a while ago. Phone 262-966-2866.
J.David
jdconrad@snet.net
PostPosted: Wed May 23, 2001 9:09 pm
Try Tivoli in Vermont and ask for Paul Wheeler. They are very good to work with and are reasonably priced.
PostPosted: Wed May 23, 2001 9:53 pm
The as-built stays are (qty 414) 15/16", (qty 44) 1.125 straight and (qty 66) 1.125 tapered. I think the 1" looks like a good replacement size for the 15/16", but I dont have the 1.125 stays out yet to see what the sheet looks like. I may need a consult before I'd go to 1.25, though I have a message into Steve and he may have the taps.
Thanks for the lead
> Two thoughts:
> J.David
heisler1607@earthlink.net
PostPosted: Wed May 23, 2001 10:04 pm
What size is your engine? Are you geting it ready to run? Where are you located? My son and I have a 40 ton Vulcan 0-4-0T that is close to being restored. We are located in Indiana and may be able to be of some help to you. Let us know and good luck with your project.
JCG
johncgra@locl.net
PostPosted: Sat May 26, 2001 11:06 am
I should be able to supply the taps you are looking for. Let me know.
drotarinoh@webtv.net
