It is currently Tue Nov 24, 2026 6:39 pm
 Post subject: White Pass tries biodiesel
PostPosted: Fri Apr 13, 2007 9:08 am
>http://www.environmental-expert.com
>Diesel Oxidation Catalyst for Locomotive
>Courtesy of DCL International Inc.
>Description
>A tourist touring train in Skagway, Alaska, powered by a 6 cylinder,
900 hp,
>Alco 251B diesel locomotive. The train carries tourists through a
scenic
>mountain area.
>Challenge
>Diesel odor and soot from the diesel locomotive was a nuisance to
passengers
>on the train. DCL was approached for an emission control solution.
>Solution
>DCL custom designed an emission control catalyst for retrofit onto the
>locomotive. Test results for the diesel oxidation catalyst showed a
>reduction of hydrocarbons and odor causing compounds of 90% and a
reduction
>of carbon monoxide by 99%. The customer reported a significant
improvement
>in the tour experience of passengers.
 Post subject: Re: White Pass tries biodiesel
PostPosted: Fri Apr 13, 2007 1:02 pm
If I read it right, it would seem to be a catalytic converter for the locomotive similar to UP's program in the LA basin. Bio-diesel is better, but still can smoke under quick acceleration. Generally, bio is run in a blend all the way up to 80-20. The 20% is the bio. There was an article in Trains a few months ago about the Rail Runner using bio-diesel for their locomotive fleet. There are other issues to deal with with bio as well. The worst one is the algae that grows in diesel really likes the bio. This shows up in increased filter usage.
PostPosted: Mon Apr 16, 2007 9:34 am
There are biocides on the market for treating Diesel fuel - which is also a problem with Diesel. A good sized bottle goes a long way on the order of 1000:1 if I recall correctly.
Good judgement comes from experience, experience comes from bad judgement.
PostPosted: Mon Apr 16, 2007 11:45 am
ATSF 3751 is also burning biidiesel this weekend.
JKB
