It is currently Fri Oct 16, 2026 11:59 pm
 Post subject: A-5 gang car help
PostPosted: Tue Oct 11, 2016 10:11 am
I have been given the task of re-assembling a Fairmont A-5 car that a former member started restoration on and then left the organization 5 years or so ago. I have gotten the Waukesha FC engine to fire and run briefly after much part swapping and trial and error.
What I would really like is to track down a manual or a parts breakdown as some components are a mystery and a few are missing as things have been scattered over the years. A big sticking point right now is the throttle linkage seems to be MIA.
We have a large supply of parts from other donor units over the years but no complete cars to reference.
If someone has a manual they could scan or copy it would be a great help.
Thanks
 Post subject: Re: A-5 gang car help
PostPosted: Tue Oct 11, 2016 10:33 am
I have an A-5 manual. Do you know the age of the car or the series it was? A-5-B or A-5-C, etc.
Some also had a group # A-5-C-1.
If I have a duplicate (which is probable) I can sell it to you, if not, I'll copy the original in my archive.
I've got over 200 Fairmont manuals in my archive......
DaveW.
PostPosted: Tue Oct 11, 2016 12:09 pm
To be totally honest I have no idea what it is other then A-5. I do know that it is a longer wheelbase then the other frames we have. It also has the same windshield/ front wall configuration front and back but this may have been a modification done later in life. If it helps it has a wakesha FC, borg warner t-9? 4 sp tranny without reverse. The rear end has reverse and forward gears.
PostPosted: Tue Oct 11, 2016 1:29 pm
I don't know how close it would be, but we have an A4 with the 4cyl Wakeshaw engine that I will be parting out soon. It is 99% complete and may have parts you need. Or you could come over and take photos and measurements if needed. Let me know.
PostPosted: Tue Oct 11, 2016 3:30 pm
I found this chart http://home.pcisys.net/~glenn_butcher/r ... types.html
So I will have to measure the wheel base next weekend when I am down there.
Fairmont A5 109 1/2" 1700' 52" 20" stamped st 12 Continental Red Seal H9 4cyl L Brown-Lipe 3sp Gang Car
Fairmont A5-A
Fairmont A5-B (1935) 104 3/4" 1660' 44" 16" stamped st
20" opt 9 Waukesha FK 4cyl L (1937 bulletin specs Waukesha FC) 4sp
Fairmont A5-C 107 3/4" 1800' 16" stamped st 8 Waukesha FC 4cyl L 4sp
Fairmont A5-D
Fairmont A5-E 1966-1974 803 109" 1840' 53" 16" stamped st 8 Waukesha 4cyl L 4sp
Fairmont A5-ZU Waukesha FC86 Warner T9 w/reverse multi-gauged from 30" to 66"
weight: 3216'
PostPosted: Mon Oct 17, 2016 10:22 am
I actually found the ID plate this weekend in a box of spare parts(junk) the car is an a-5c.
I have been able to start the engine finally and it actually sounds good for not being tuned yet. The gas keeps overflowing out the inlet of the carb guess I need a rebuild kit for the carb and a float adjustment.
Someone in the past converted the engine to a more modern GM alternator but really bodged up the brackets making the whole setup an absolute pain to deal with. It would be a simple task to make new brackets at work with a whole machine shop available but unfortunately that is 1 1/2 hours away. I'll manage I guess.
The muffler appears to be a tractor muffler from TSC and is loud as hell, does anyone have a recommendation for a modern automotive type that would be easier on the ears and neighbors?
PostPosted: Mon Oct 17, 2016 11:17 am
EWrice wrote:
.. we have an A4 with the 4cyl Wakeshaw engine that I will be parting out soon. It is 99% complete...
If it's 99% complete, why part it out instead of restoring it?
PostPosted: Mon Oct 17, 2016 11:25 am
You might find some help here: http://www.fairmont.txrrhistory.com/MCC ... CCAID.html
The Martin County Historical Society has all of the Fairmont records. If you know the builder's number of your car they can provide a copy of its birth cirtificate. See here: http://fairmont.org/mchs/rwmotors.htm
PostPosted: Mon Oct 17, 2016 12:33 pm
Even though it is complete, it has a bent frame and major engine damage. I have a slightly newer A4 that some of the parts will go towards to make it useable again. Sometimes we have to pick our battles.
PostPosted: Mon Oct 17, 2016 7:54 pm
So are the wheels avaible? Where are you located?
PostPosted: Mon Oct 17, 2016 10:06 pm
The frame and wheels will be re purposed as a push cart with rails on the deck for our tie inserter (idea from fairmontdave). If you need wheels, I know we have some extras. I can see what might be available.
PostPosted: Tue Oct 25, 2016 10:13 am
Well I ran it across the parking lot Sunday. Needs some adjustment and lots of little things like wiring that does not involve holding a cable to the positive terminal of a battery to start it.
What type of air filter did these use? I can't seem to find any in our junk/spare piles.
https://www.facebook.com/kerry.scaife.9 ... 240297303/
