It is currently Mon Oct 05, 2026 1:19 am
 Post subject: 5-1/2" Superheater Flues?
PostPosted: Tue Apr 30, 2019 3:54 pm
Last edited by Kelly Anderson on Mon Sep 30, 2024 3:03 pm, edited 1 time in total.
 Post subject: Re: 5-1/2" Superheater Flues?
PostPosted: Wed May 01, 2019 10:51 am
Kelly,
Does Anderson Tube not handle this size?
Eric
PostPosted: Wed May 01, 2019 12:03 pm
hadder wrote:
Kelly,
Eric
According to AT's website, they carry 5.50" SA-178 tube. I think Kelly is after a certain gauge thickness that has become scarce. His complaint was the available thicker gauge tube heat absorption rate would cause issues with the fluesheets bowing and/or star cracking from unequal expansion/contraction with lighter gauge 2" tubes. Might be wrong, but that's what I recall.
Jeff
<Some relevant quote.>
PostPosted: Wed May 01, 2019 1:59 pm
PostPosted: Wed May 01, 2019 10:43 pm
But why 8 or 9 gauge with the problems that can come with using a thicker wall tube? Have you checked the mills, not the fabricators, to see if they are currently running 5.5?
PostPosted: Thu May 02, 2019 7:34 am
PostPosted: Thu May 02, 2019 1:05 pm
Kelly,
I didn't take into consideration the engineering behind increased thickness and OD of the tube. Nope, use 3.5" flues so 10 is just fine.
PostPosted: Thu May 02, 2019 4:28 pm
While on the subject of tubes - we are looking for a source for 10 ea. #SA-178-A 1.50" OD X .135 WASL, 20 ft lengths for repair of super heater assemblies.
A local supplier indicated they had a source, but due to a substitution and bad communications, when they arrived they were only .065 wall.
We are back to looking for a source. Any suggestions?
PostPosted: Thu May 02, 2019 5:10 pm
[quote="Dick_Morris"]While on the subject of tubes - we are looking for a source for 10 ea. #SA-178-A 1.50" OD X .135 WASL, 20 ft lengths for repair of super heater assemblies.
shows on the floor.
https://www.metroboilertube.com/inventory.html
PostPosted: Thu May 02, 2019 8:08 pm
Bobk - Thanks, we sent them a note.
PostPosted: Fri May 03, 2019 8:02 am
Superheater units are generally made of ASME SA-106 grade Gr. B or C compared to SA-178A which is typically used for flues and tubes. The ERW seam may promote corrosion of the units prematurely compared to the seamless SA-106 grade. You may have better luck with availability as well. Food for thought anyway.
Best,
DC
