It is currently Sat Sep 26, 2026 2:19 pm
 Post subject: P.P. & S. 700/S.P.700
PostPosted: Mon Apr 30, 2001 11:13 am
I was just looking around in the Ghost Depot site (http\ghostdepot.com) and came across a picture of Southern Pacific 4-8-4 #700 in the section under "Other Railroads." It looks remarkably like S.P. & S. #700 and they are both Baldwins. Were they constructed to the same general plan?
kenneth.willis@marad.dot.gov
 Post subject: Re: P.P. & S. 700/S.P.700
PostPosted: Wed May 02, 2001 4:48 pm
There is no such engine as Southern Pacific 4-8-4 #700. It looks like SP&S #700 because it is. Someone evidently got confused or didn't type the "&S".
> general plan?
steameng@att.net
 Post subject: Re: P.P. & S. 700/S.P.700 *PIC*
PostPosted: Wed May 02, 2001 5:21 pm
That's what I was expecting too, until I saw the photo. The engine is clearly lettered "Southern Pacific" on the tender and "700" on the cab. But apart from having the same wheel arangement, the same number, and a few road name initials in common, it is a distinctly different engine from the SP&S 700.
> "&S".
rjenkins@railfan.net
PostPosted: Thu May 03, 2001 1:26 am
> from the SP&S 700.
The SP #700 was an early '30's Baldwin product, circa 1931. I believe this locomotive went to Texas. The SP&S 700 is a '38 Baldwin. They do have a builder's family resemblance, however, the give away is in the size of the firebox. The NP design (SP&S 700) is considerably larger than its SP distant cousin.
http://www.sps700.org
johnpcox@juno.com
PostPosted: Thu May 03, 2001 1:32 am
Other major differences are the tender, the 2nd axle of the trailing truck (the NP design had 45" wheels to allow for a booster, the SP did not), the air reservoir (the NP design has the reservoir cast in the frame), and the SP&S 700 has BoxPok drivers. These drivers are obviously smaller than the SP&S 700's, probably 73" versus 77's. The sandbox lines are also different.
Many differences.
johnpcox@juno.com
PostPosted: Thu May 03, 2001 8:27 am
I have to ask, what color is the boiler jacket? Was this color used only for the builders photo?
smokebox1@home.com
PostPosted: Thu May 03, 2001 10:23 am
> different.
> Many differences.
SP 700 was a GS-1 , one of 4 that were assigned to the T&NO. It was later transfered to the Pacific Lines in the early 1950's and given the number 4470.
ironbartom@aol.com
